Check the Key Notes on Museum CD Message #5 Posted by Gene on 11 Feb 2003, 3:58 p.m., in response to message #1 by R Lion
From 1979-1980, HP ran a couple of articles about converting HP-67 programs to run on the HP-67.
In most cases, this wasn't too tough.
The 7DSZ instruction you point out is essentially "DSE 25" on the HP-41. PRTX is just a long pause on the HP-41. You could just replace it with PAUSE.
Register 25 was the I register from the HP-67. You can see this with the numerous RCL IND 25 like instructions in the HP-41 translated program.
Worth a shot. I can probably translate it for you to see if it works, if you have some test cases to run on the program afterwards.
