HP Forum Archive 10
HP 15C, Nimber Format
Message #1 Posted by Terry Monaghan on 4 Feb 2003, 11:49 p.m.
A friend of mine has a HP 15C. It displays a decimal for a comma, and a comma for a decimal. How do you fix this problem?
Re: HP 15C, Nimber Format
Message #2 Posted by Vieira, Luiz C. (Brazil) on 4 Feb 2003, 11:53 p.m.,
in response to message #1 by Terry Monaghan
Hi;
there is one sequence to toggle from one mode to the other:
- swithc the calculator to OFF - press and keep pressed the [.] key - switch teh calculator to ON while holding the [.] key - release the [.] key
Do it as many times as you need to change from dot to comma.
Cheers.
