Tones on the HP48GX Message #1 Posted by Maestro on 22 Jan 2003, 8:50 a.m.
I know that this is a ridiculous question, but I'll ask anyway.
What started out as a quick effort to write a small program to make my 48GX play a little tune (or even a short tone sequence) for the kids has turned into a quest. (You've got to start early if you want to get them hooked on RPN !)
Since the "manual" doesn't really elaborate on the use of tones, (at least I hadn't found it by midnight last night) what command should I be using ? I was trying to write a small subroutine which would play a tune, then run it.
I understand the need to use a frequency, like 1500 hz, and duration, like 0.5 seconds and the "BEEP" command. Putting it all together is the trick.
Maybe I was too tired, or maybe my knowledge of my 48 needs supplementing, but whatever help I can get, I would appreciate greatly.
