Re: Spice battery flex circuit - built from scratch - Battery contacts Message #8 Posted by Christof on 23 Jan 2003, 10:00 p.m., in response to message #7 by Renato
I've got two 32E machines undergoin restorative surgery right now. If anyone has picture to help me trace (some of the paths at the battery side are eaten to the point of non recongnizability......
I have considered tape and wire, but I think I may try using modeller's house elctrical wiring- which happens to be flat ribbon tape (with two copper conductors side by side)!
if you have a store that caters to hobbyists who work on model railroads and model houses (extravagant doll houses), you may find some.
for batteries, why not solder the leads from 2AAA cell srping holder? (assuming one will fit.) a pair or high cap aaa rechargables should work fine.
