Re: HP-29C Message #2 Posted by Larry Corrado on 18 Jan 2003, 7:41 a.m., in response to message #1 by Larry Smith
I've often had those same symptoms with my HP-21 and 25's. In all cases it was the battery pack, or battery connection. Sometimes just applying finger pressure to the outside of the pack would fix the problem. I think you have a battery problem, either with a bad pack or a bad connection.
If you feel comfortable doing it, I'd try powering it up from a regulated power supply. Or if you don't mind a bit of damage, carefully cut open the battery pack and try a new pair of AAs.
Good Luck!
Larry
