Re: HP-41C/CV/CX display contrast Message #8 Posted by Juan J on 16 Jan 2003, 12:21 a.m., in response to message #7 by David Smith
Earlier fullnut 41s' displays had no means of adjusting the contrast. Halfnut 41s not only had adjustable display contrast, but also an extended character set, which can be accessed using M-code.
The HEPAX module uses a bug in the 41's operating system to squeeze some extended multi-functions, as the manual calls them, that are executed with the HEPAX nnn function. Incidentally, [XEQ] HEPAX 005 regulates display contrast on halfnuts using a number in the X register (the number must be entered befores executing the function.) The default is, if I remember correctly, 5, and the contrast can be changed from 1 to 14.
Now there's something I've been wondering about lately. WOuld it be possible to plug an HEPAX into a halfnut, set the contrast, and then unplug it? If applicable, could be a way to adjust the contrast on newer (halfnut) 41s. I only have a fullnut 41C and a halfnut 41CX and cannot try this. Perhaps anyone outthere with an HEPAX and two halfnuts?
