Re: Has anyone successfully connected an HP-41 to a PC? Message #5 Posted by Christoph Klug on 7 Jan 2003, 5:10 a.m., in response to message #1 by Steve
Dear Steve,
Up to now the HP-IL/PC Interface Card is the defacto standard for interfacing the HP41 to PC. And only this solution gives you the most advantage features.
In combination with the new EMU41 full version from Jean-Francois Garnier you control some real and virtual IL-Devices, for up and downloading data, programms, non-normalised-numbers = NNNīs, X-memory files, CCD-Module matrix files ....
Furtermore you realise fast HP41 Barcode plots, multi column program plots, and last not least you get an advanced HP41 emulator solution which includes CX functions plus advanced modules like PPC, CCD, ZENROM, HEPAX and RAM-Box features....
Please refer to "HP41-PC Gateway & Emulator" at HP-Museum forum which was anounced end of December 2002, there you get somem more details about professional and advanced HP41-PC interfacing including up and downoading data and programs
Best wishes from Germany - Christoph
