Hp-21 problems after battery leak. Message #1 Posted by Harry (Germany) on 24 Dec 2002, 8:42 p.m.
I just bought a HP-21 that had major corrusion from an oöd battery pack. i cleand it all up and it worked fine for a few minutes. After i turned it off and on again, it didn't.
If i turn it on and off several times, it sometimes does wired things like flashing numbers in the display or countin 0-9 at the last digit.
Sometimes it works correct too.
I thought it might not be producing the 4Volts for the display. Where can i measure those 4 Volts if that part of the circuit works fine?
Sorry for my bad english and thanks in advance,
Harry
