Re: how to see what programs on a ROM (stat pac) Message #2 Posted by Vieira, Luiz C. (Brazil) on 16 Dec 2002, 3:42 p.m., in response to message #1 by David E
Hi;
the HP41CX's CAT 2 is slightly different.
When you execute CAT 2 in a CX, only the HEADERS appear (to speed up, you press any key except [R/S] or [ON]). When you see the header for the module you want (STAT), you press [R/S] to stop catalog, then [ENTER]. Each available function/program for the specific module is listed. If you want to go back to header listings, press [R/S] again and [ENTER].
In some situations, when you have modules with many funtions, this feature is a lot desirable.
Hope this helps.
