Re: 71b 41 translator has Forth? Message #2 Posted by Philip on 3 Dec 2002, 10:21 a.m., in response to message #1 by Andy
Well, yes the 82490A HP41 Translator ROM does contain FORTH becasue the emulation is based on FORTH. It also contains an editor. Both FORTH and the editor are accessible with the Translator ROM. However, the FORTH system in the Translator ROM is not identical to the FORTH/Assembler ROM. The Translator ROM does NOT contain the Assembler. According to the Translator Manual on page 74, "The HP-41 Translator Pac does not contain an assembler, but its built-in word set contains additional floating-point words and other HP-41 words not found in the FORTH/Assembler ROM."
So, unless the ROM listed is a modified version of the 82490A, it doesn't support Assembler.
