Re: HP41C Message #2 Posted by Bill Wiese on 2 Dec 2002, 2:58 p.m., in response to message #1 by Ray Fuller
Ray...
*Sometimes* HP41s (C/CV/CXs) don't always power up after a "big sleep", battery change after discharge, etc.
Before we go on, I trust that the N cells are all good and are inserted properly? No corrosion on the 41C batt terminals in the compartment?
Do a full reset (i.e., try for MEMORY CLEAR). Try this also WITHOUT the batteries installed. Short the terminals, let sit for awhile, rinse, lather and repeat...
There IS a chance that over time the polymer & PCB connector "sandwich" between the two halves has lost contact, tension, etc. Lightly but firmly squeeze the calc front & back, along the system keys (ON/USER/PRGM/ALPHA) and down by the numeric area (centered on [5] key).
Bill Wiese
San Jose, CA
