Re: EDUCALC SERVICE MODULE - One question Message #4 Posted by Vieira, Luiz C. (Brazil) on 28 Nov 2002, 2:54 p.m., in response to message #1 by Michel Beaulieu
Hi;
execute [CAT] 2 with nothing but this module. The standard available functions should be:
-TIME 2X
-CX TIME
-EXT FCN 2X
-CX EXT FCN , where 2X is the version/revision type, being X an id (letter). If any other module is plugged in AND it has a header (module's name), this header should appear between -CX TIME and EXT FCN 2X. If you plug a card reader, you would have:
-TIME 2X
-CX TIME
CRD RDR 1X
-EXT FCN 2X
-CX EXT FCN , being 1X its identifier.
Plug in the module and execute [CAT] 2. If nothing appears, chances are this is just a double X-Memory module.
One question: I do not know if it is possible to plug a ROM module in an HP41 and have its functions suppressed from [CAT] 2. Does anybody know anything about it?
Regards.
