HP Forum Archive 09
Double A531D Module???
Message #1 Posted by Michel Beaulieu on 26 Nov 2002, 11:11 p.m.
Hi, my father give me when he died a HP-41CX and a lot of accessories that i slowly learn about on this site and other. But there is a module name "Double" and number "A531D" that i don't know anything about: It's a silver tape on the module and not a "engraved" white encryption. Can someone tell me the purpose of this ROM... or RAM... and how to acess it???
Thanks...
Michel Beaulieu,
younger physic teacher than my father who normally work with TI-Graphic calculator... So excuse me if this module is well known!!! :-)
Re: Double A531D Module???
Message #2 Posted by Emmanuel, Normandy (France) on 27 Nov 2002, 3:10 a.m.,
in response to message #1 by Michel Beaulieu
Dear Michel, It seems to be the famous 'Educalc Service Module'. Sincerely yours. Best regards from Evreux
Message #3 Posted by Vieira, Luiz C. (Brazil) on 27 Nov 2002, 8:51 a.m.,
Hi;
is there any difference when you list CAT 2 contents with and without the module?
I was once told (rumor?) that double memory modules were available for the HP41C, say, two 82106A in one single case. Is it true or just a fairy tale?
If no extra label appears when CAT 2 is executed with this module, I suggest testing it in an HP41C (neither CV, nor CX) and check for extra regular registers.
Best regards
Message #4 Posted by Richard Garner on 27 Nov 2002, 9:49 a.m.,
in response to message #3 by Vieira, Luiz C. (Brazil)
I have one of the double Extended Memory ROMs. It just says MEMORY on it. If it is a double Etended Memory Module, you can do a CATALOG 6,I think, on the 41CX and it should show a total 600 Bytes if Extended Memory is empty. It has been awhile sense I looked at the Extended Memory CATALOG.
Re: Double A531D Module??? NEW CLUES
Message #5 Posted by Michel Beaulieu on 27 Nov 2002, 12:10 p.m.,
I remove the module and i saw another label "EDUCALC MODULE SERVICE". I also made a CAT4 with the module i get 600 and without the module i get 124... Perhaps "you" can find now the utility of my module :-)
Thanks for answer!
I have another question; i tried to FIX the decimal with "." but nothing, FIX9 get 9 decimals, FIX0 get 0; normal you say but i hate when the diasplay is full of 0 like 0.0000 or 0.000000000. How to get all the possible decimals without all these 0 when i hit CLX?
Message #6 Posted by Massimo Gnerucci (Italy) on 27 Nov 2002, 12:37 p.m.,
in response to message #5 by Michel Beaulieu
No way. There is no STD (as it was then named) format on the 41 series.
I like to have a full display instead: CF28 (SF29) FIX9 is my standard boot procedure on a 41...
Greetings,
Massimo
