Re: Powers of Matrices on 49G Message #4 Posted by Karl Schneider on 28 Nov 2002, 3:12 p.m., in response to message #2 by James M. Prange
Interesting! This brings up the logical question: How would one perform A^7 on other HP's with built-in matrix support? Here are my answers:
HP-42S:
y^x is not supported for matrices. Don't use the x^2 function, because that will only square each matrix element. Instead, after loading the square matrix with the descriptor in the X-register:
ENTER, ENTER, ENTER, X, X, X, X, X, X
or,
ENTER, ENTER, X, ENTER, ENTER, X, X, X
HP-15C:
The result matrix cannot be stored to the same name (A, B, C, D, or E) as the name of either multiplicand matrix. With the square matrix loaded into "A":
RCL MATRIX A, ENTER, RESULT B, X, ENTER, RESULT C, X, RCL MATRIX B, RESULT D, X, RCL MATRIX A, RESULT B, X
A bit cumbersome, but there's enough memory to perform A^7 (or any n) for a 4x4 real-valued matrix A!
HP-41 with Math, Math/Stat, or Advantage module:
Suggestions? I have the eqipment, but haven't learned the added-on matrix functions for the 41.
