Re: HP41CX Message #3 Posted by andy on 21 Nov 2002, 10:26 p.m., in response to message #2 by Dave Mabry
As an alternative to the technique given in the previous post, I've used adhesive-backed copper tape without soldering. My old 41cx (which had some corrosion too) has been working fine ever since. The a special copper tape with electrically conductive adhesive backing (made by Chomerics...we use it for EMI testing).
If you would like, email me your address and I'll send a few strips of it in the mail to you. Its 1" wide and you can easily cut it with sissors to fit. Then just peal off the backing and stick it in place.
Make sure you don't use aluminum tape since it could cause bi-metallic corrosion.
Andy
