Re: HP 82066B charger question Message #2 Posted by Vieira, Luiz C. (Brazil) on 19 Nov 2002, 9:44 a.m., in response to message #1 by Juergen Rodenkirchen (GER)
Hi;
I use one 82066B with my 9114A Disk Drive. The specifications for many chargers are the same: 3 Watt (in some of them, it's 3 VA; if the power factor is closer to 1, they are about the same) 8 Vac
These specs - 8Vac, 3W - go to 82066B, 82040B and 82059B; these are the ones I have in hands.
Hope this helps.
Cheers.
