HP Forum Archive 09
I´m fixing a 41cv. It is now almost ok, but <beep> and <tone> do nothing. Any suggestions ?
May be your 'beeper' is dead or one of the wires cut. Please check. Youtrs.
Also check flag 26 (audio enable). I assume you already did, but... Wires are better candidates.
I checked the wires. Black wire was broken at the soldering point. It is now ok. Thank you, Emmanuel and Andrés.
