HP Forum Archive 09
HP71B - how slow can it be?
Message #1 Posted by Thomas Falk on 9 Nov 2002, 7:03 a.m.
Hi everybody,
I have a HP71B with a HPIL module and this machine seems to be very slow. In the program
10 a=0
20 print a
30 a=a+1
40 goto 20
one loop needs 3 seconds after a complete reset (attn-/ and 3). After switching off the HPIL by "off io" one loop needs 0.6 seconds only. But I have seen it running with about 10 loops per second once, but cannot reconstruct the conditions.
My question is: How fast should a normal HP71B be and what influences its speed for good or bad?
Thanks for any hints,
PS: I don't have a manual (yet), please be patient with me.
Re: HP71B - how slow can it be?
Message #2 Posted by Raymond Hellstern (Germany) on 9 Nov 2002, 11:50 a.m.,
in response to message #1 by Thomas Falk
pull out any modules, including the IL, put the machine on mains (Netzstecker rein;-), run the program again.
Maybe you have installed some software which reacts on interrupts, like a running clock, or some other background task. Remove them, and you'll see;-)
Raymond
Message #3 Posted by J-F Garnier (France) on 9 Nov 2002, 11:51 a.m.,
Use DISP instead of PRINT. PRINT is used for external hpil printer, although it can also be redirected to display by typing: PRINTER IS *
J-F
Re: HP71B - how slow can it be - Thanks!
Message #4 Posted by Thomas Falk on 11 Nov 2002, 3:20 a.m.,
in response to message #3 by J-F Garnier (France)
Thanks to everybody who helped, especially to the one responding by email.
I didn't expect such things like 'delay' for the display in Basic.
Probably I should really get a manual.
Thanks again.
