Re: 10C: asterisk occasionally flashes on LCD Message #2 Posted by Vieira, Luiz C. (Brazil) on 7 Nov 2002, 3:36 p.m., in response to message #1 by Therese
Hi;
that's correct, Therese: the blinking asterisk means that the batteries are running low for the internal sensors. So, you may also have a bad contact (any sort of dirt will cause that, even finger fat). If you have the means, test each battery; maybe one of them is getting low.
It's also good practice checking for batteries leakage (monthly); your HP10C (as you are probably fed up listening) is a lot precious, and this is a simple check to keep it alive.
Best regards.
