Another solution Message #4 Posted by Mike on 3 Nov 2002, 12:05 p.m., in response to message #1 by Robert Pietersma
Another solution, is to use fuel line tubing. Costs less than 10 cents per fix. Fuel line is available at model hobby shops almost everywhere.
This article shows how to repair the 67 but the same material works for the 41 reader.
HP-67 Card Reader Repair
The one that is best is a matter of preference. I like the fact that there is more surface contact with the tubing on the card and shaft, is nearly identical to the original and is the exact size required. I have fixed nearly 100 readers using this solution and it works great.
