Re: hp9122d floppy drive Message #2 Posted by Alex on 31 Oct 2002, 1:03 p.m., in response to message #1 by andy
I don't think this will work. The 9122D is a "SS-80" command format drive, while I'm pretty sure the 9114-type drive is the older "Amigo" format, and I would think the HP-IL stuff is designed for "Amigo". If you could find a 9121-type drive, that is "Amigo" and _might_ work. I did not have any luck connecting a 9114B drive to a HP1631D logic analyzer using the 82169 converter (sort of reverse from what you are trying).
Alex -
www.calcmuseum.com
