Re: Is it true HP isnt making the 49G Message #2 Posted by Ellis Easley on 27 Oct 2002, 3:21 p.m., in response to message #1 by Criss P.
Shortly after the 32SII was discontinued, while there were still units in some stores for the list price of $60, the price on Ebay went to $150. If this is repeated on the 49G (when and if it goes away), the price might go up to around $500. It might truly be the last RPN, unless something happens.
Ideas come to me while I am writing my missives here: television sets nowadays come with a disposable (and easily replaced with a generic equivalent) remote control that contains the codes to operate hundreds of different VCR's, cable boxes, and now probably DVD players, only a tiny fraction of which any user will need. Why can't the makers of calculator IC's (I think Mike Sebastion says it's pretty much down to Toshiba) be prevailed upon to add RPN capability as a user option? From studying the early TI calculator booklets, I understand that "AOS" uses as much, or more, RAM as the 4 level stack. Not only do numbers need to be remembered, operations are also held in a stack until the "=" key (or parentheses or whatever) is pressed.
Maybe HP will bring this up with their new suppliers. HP certainly has the code required, and could help a supplier incorporate it.
