Re: HP41 Memory Modules Message #2 Posted by Vieira, Luiz C. (Brazil) on 27 Oct 2002, 10:15 a.m., in response to message #1 by Ty Rogers
Hi;
plan memory modules as Quad Memory and single 82106A will ONLY work with the HP41C; both HP41CV and HP41CX will not use them and you may disrupt calculator operation if you try using them.
X-Memory will work fine directly in an HP41CX, because it can only be ccessed by X-Functions. Anyway, if you have an HP41C/CV with X-Functions, X-Memory will work fine, too.
Just an advice about X-Memories: maximum of tweo modules in a plan HP41 (I do not know anytinhg about modified calculators). And, in this case, a simple rule: plae them sided to eachother, never in the same column: internal connections will not allow two X-Memory to work in the same column.
Hope this clarifies.
Cheers.
