Re: Restoration question Message #3 Posted by Randy Sloyer(US) on 24 Oct 2002, 5:50 p.m., in response to message #1 by Don Davis
Here is a thread from August about trying to brighten the case on a 97:
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv008.cgi?read=21087
I don't know if these would help on the keyboard area, but there were lots of good clean-up tips in it.
As for having a new label printed, I think it would be cost prohibitive. The cost of making a silk screen alone would be in excess of $100 when you consider the camera work involved. There would be two images involved since the 25 label is 2 colors. You could make one screen with both images, but it would still be a two pass printing process. I would make a screen with one image on the top, the other on the bottom and just flip the screen over in the frame. Unless you have a friend in the business, or you REALLY REALLY wanted to restore the 25, I think the cost would be out of reach. On the positive side, the silver mylar would be no problem to source.
Then again, if you could find a 50 people that wanted a label at $3-$4 each, you might be able to do it. But then that would raise the issue of copyright since the Hp logo on the label is certainly a copyrighted image. Don't want to open that can of worms here (again).
Probably a lot easier to buy a dead 25 (read cheap) for the bits. You can always use the extra feet and spare battery for a Woodstock.
