Re: HP48.EXE on HP Jornada 525 Message #4 Posted by DJ on 14 Oct 2002, 5:37 p.m., in response to message #3 by gene
On PocketPC, the top and bottom bars won't go away. The KML script you use must fit in between. The one in my previous post should work. Some of the older scripts won't fit on PocketPC because they were made for the previous version WinCE which only had one bar at the top and nothing at the bottom, giving you 20 extra pixels or so. You may have to edit the offsets in the old scripts to get them to work (a real pain). Make sure you have the latest HP48.exe as well. As I recall, there was an offset bug in a prior version. You should find the latest here:
http://web.jet.es/leobueno/soft/emu48ce.exe
