Re: HP 41CX Byte Grabber?? Message #3 Posted by Vieira, Luiz C. (Brazil) on 14 Oct 2002, 12:26 a.m., in response to message #1 by paul
Hi;
I'm not gonna tell you about wiping all memory out, but I just want to add two small advice for dealing with Synth Programming on the HP41:
1 - AVOID using [GTO] [.][.] (if you do not need to, do not use this sequence). I lost some synth sequences (in fact, their effect in memory) after pressing [GTO][.][.];
2 - if you have any mass storage device (card reader, HPIL any) that can save status information, use it; the assignment and the byte grabber (jumper) will be saved and retrieved anytime you want to.
Does it help?
Cheers.
