Improving your posts' view (was Statistics on HP15C) Message #3 Posted by Vieira, Luiz C. (Brazil) on 14 Oct 2002, 11:26 p.m., in response to message #2 by Tom Sherman (Maine)
Hi, Tom;
if you have the time for it, read this here. If not, here is the tip:
if you have a text you want to be seen exactly as you type it here, with all line-feeds and monotyped spaces, simply put a [pre] before its first character and a [/pre] after its last character. Your text would look like this:
R2: n, # of data points
R3: sum of x values
R4: sum of x^2
R5: sum of y
R6: sum of y^2
R7: sum of xy
To accomplish this, you type:
[pre]R2: n, # of data points
R3: sum of x values
R4: sum of x^2
R5: sum of y
R6: sum of y^2
R7: sum of xy[/pre]
Hope it helps.
