Re: Xpander - Can you add some impressions? Message #10 Posted by Y K Wong (Singapore) on 27 Sept 2002, 12:10 a.m., in response to message #4 by Vieira, Luiz C. (Brazil)
Hi Vieira,
In fact I have more problem with the Xpander than I have mentioned earlier! In the manual, it was stated that the batteries need to be recharged by the supplied charger for nine hours, I did that but they won’t hold the charge at all. From the advice of the seller, I have the NiMH removed and put them into a standard NiMH charger for about 5 minutes and then return them to the unit, there after it is fine! I was told that if the batteries are left too long without a charge, the recharge circuit inside the unit will no longer charge them.
It was some struggling on the first two days of ownership; hence, I don’t have much time to explore the unit yet!
