Re: HP-71B dead! Message #3 Posted by James Browning on 25 Sept 2002, 10:32 a.m., in response to message #2 by Andreas Stockburger (EU)
Yes, Andreas, I removed alll cards (including HP-IL) so it is completely empty.
Using batteries or using the Power supply unit has no effect and the system will not start (nothing on the LCD).
I will try and short the battery contacts tonight but I'm not sure if this will make any difference!
I did not know removing a ROM whilst the machine was powered on would make any difference!!!!
Can you (or anybody) tell me if this is a well known issue?
Thanks
James
