Re: Support on HP 9825B case Message #2 Posted by Dave Mabry on 23 Sept 2002, 1:55 p.m., in response to message #1 by Dario Rodriguez
Hello Dario,
If you are talking about using a PC to control some equipment that is controlled by the 9825 through HPIB, then you would probably want to look at the company National Instruments. They make some of the best cards that implement IEEE-488 (the current name for HPIB) on the market and support those cards in current operating systems.
You will probably have to rewrite your applications since I know of no software that can run the programs from your 9825 directly on the PC.
I hope this is of some help.
Dave
