Re: 12C Manual on HP site...NOT! Message #10 Posted by Vieira, Luiz C. (Brazil) on 21 Sept 2002, 9:05 p.m., in response to message #9 by Scuba Diver
Hi;
I am not sure if I did not understand you or I did not express myself right. What do you mean by << The entire manual completely fills a sheet of A4 paper? >>?
The final printing contains 161 pages, A4-size. I printed mine both-sides (odd- and even-pages facing each other) and they look great.
I did not try the letter-size paper, but there is also a margin left when using the A4 (I did not measure it). I did not like the final layout, because it is ugly! And it also has some errors, like keystroke sequence different of the program code in the same program line.
I used Adobe Acrobat Exchange so I copied the complete ASCII text for the manual to a file, and I'm rebuilding it so it will fit anywhere. In fact, I want to reduce it to a size that matches the original HP12C Owner's Handbook and Programming Guide. The problem is that the images (all boxed keys are bitmap images, not ASCII characters... sob!)are not transfered, only text. I hope the final "product" worth the job.
Cheers. And forgive my lack of English understanding...
