HP-16C Question Message #1 Posted by John Smith on 19 Sept 2002, 6:16 a.m.
Hi everybody,
Just a question for all those amazingly knowledgeable
HP-programming experts in this Forum. I've recently got
a brand-new HP-16C, manuals and all, and have tried to
program a very simple calculation, for test purposes but
mostly for fun.
The problem is, I know next to nothing about this
particular machine, which has a very different function
set from, say, an HP-11C or 15C, and though what I'm
trying to do seems pretty simple, I can't figure out how
to do it nor can make any sense of reading the manuals.
The question is: I'm trying to perform a pure floating
point calculation (not octal, hexadecimal, binary or
whatever, just plain floating point), but there's a time
when I need just the INTeger part of a floating point
value. In an HP-11C or 15C or almost any other model, I
would simply use the built-in INT function, but either
I'm too dumb to notice, or there seems to be no INT function
on the 16C !
Now, I'm sure there must be some easy way of doing
just that, getting the INTeger part of a floating point
value, and then go on performing more floating point
computations with that value and the rest of the 4-level
floating point stack unaffected.
Can it be done ? How ? I just can't believe
it can't, and I'd rather blame myself for failing to see
the probably ultra-obvious correct procedure.
Any help would be greatly appreciated, many
thanks in advance, and excuse me if my question is
way too silly.
