Re: HP 15C Message #4 Posted by Randy Sloyer(US) on 18 Sept 2002, 5:25 p.m., in response to message #1 by David Barnes
If you have the correct batteries installed in the proper direction, consider the unit may need a hard reset. Sometimes when the unit has has been at zero voltage for a time, they don't want to wake up.
The Hp suggestion is to take a small short piece of wire and lifting the plastic flaps, short the battery stack out with the wire for just a brief instant. This drops the voltage to zero and allows it rise slower than if you shoved the cells in. Yes, it sounds crazy, but it works.
