Re: A solution for HP-49 array indirect addressing Message #4 Posted by Vieira, Luiz C. (Brazil) on 16 Sept 2002, 10:02 a.m., in response to message #3 by Karl-Ludwig Butte
Hi, Karl;
another possibility is using EVAL instead of ->NUM (that's what I used). In order to indirectly address to any element in any data array, that's the one option I know.
As I remember well, HP48 original literature (manuals) mention this "indirect" access to array elements as 'Using Arrays and Array Elements in Algebraic Expressions' (User's Guide, 14-12). I also remember that the HP48S/SX literature ilustrated this sort of indirect access by using lists.
And yes, I am surely interested on this sort of subject. As you (and I) have discoveries/information about it, let's post them here.
Thank you. And best regards.
