Calc is defective. Return it to seller. Message #4 Posted by Raymond Hellstern (Germany) on 13 Sept 2002, 6:15 p.m., in response to message #1 by Didier
I'd return the calc to the seller immediately!
The massive battery drain is typical for an HP-48 if someone put the batteries in with the wrong polarity.
You can consider thecalc as defective,
since in fact at leat one electronical element (a zener diode ) has burnt.
So if you're sure you didn't do this you should return it to the seller.
Raymond
