Re: HP-71B Memory Modules Message #4 Posted by Raymond Hellstern on 5 Sept 2002, 6:56 a.m., in response to message #3 by Juergen Rodenkirchen (GER)
at least for tight fitting HP-IL modules,
I (carefully) insert a thin screwdriver from the opposite side of the case, and push the module out.
I your 64K module sits in port 1 or 2, this should work the other way round.
I also made the experience that my CMT 32K modules won't get out w/o some force.
Maybe they thought 'Safety first';-)
Raymond
