Re: Zengrange Ltd 41CV Emulator Card for HP-48GX too? Message #4 Posted by Frank Wales on 7 Sept 2002, 1:30 a.m., in response to message #3 by Chan Tran
It is highly likely that the emulator will misbehave in the GX, because there were some assumptions about the 48 memory architecture made in the emulator code which were invalidated by the GX.
I just tried two different versions of the emulator on a GX to see what would happen. The emulator with version 0E works up to the point where you attempt to complete number entry (for example, I typed '123 ENTER'), but then the machine hangs. Emulator version 0A seems to work okay (i.e., it doesn't hang at that point), but I didn't do an exhaustive test, and I wouldn't rely on it working generally on the GX.
[To find out which version of the emulator you have, its version code is the first two digits of the string that VERS41 returns.]
