HP Forum Archive 09
Re: HP41 Rechargable Battery Pack Repair Solution
Message #1 Posted by Andrés C. Rodríguez (Argentina) on 1 Sept 2002, 8:13 p.m.
I am not sure at all, but since I do have a few 1500 mAh AA cells, 500 mAh in N size doesn't seem that unreal to me... At least the energy density looks similar. They may be NiMH...
Message #2 Posted by David Smith on 1 Sept 2002, 11:03 p.m.,
in response to message #1 by Andrés C. Rodríguez (Argentina)
Yes, you can get over 1800 mAH in a AA NiMHcell. The cells in a 41C rechargeable pack are 1/N... 75-80 maH in NiCad, 150 maH in NiMH. The 1/3AAA mentioned before are a LOT smaller than the 1/2N size (remember volume and charge density go down with the square of the diamter). 50maH in Nicad is about it. I have not seen NiMH cells in that size (or looked for them either).
