Re: HP-71: MakeLEX Message #2 Posted by Raymond Hellstern (Germany) on 29 Aug 2002, 9:57 a.m., in response to message #1 by Juergen Rodenkirchen (GER)
$'=RPT$($pattern,n)
where $pattern is repeated n times, which gives $'.
Example: R$=RPT$("ABC",4)
Afterwards R$="ABCABCABCABC"
It seems you need the small HP-71 LEX file called STRINGLX,
which adds some nice string manipulation functions.
If the above example is the only occurence of RPT$,
you can substitute it with a string of 16 '-'.
Raymond
