Re: HP41C Message #1 Posted by J Tiers on 27 Aug 2002, 12:01 a.m.
I will second that.
If the material is indeed ABS, then methylene chloride is a good welding solvent. Our vacuum forming vendor assembles parts for us with it, and it ends up just like a molded part. Breaks again as if it were a solid piece.
I'd go with the wire, the reason it broke is that it wasn't strong enough to start with, wire re-inforces it.
