Re: HP41C Message #4 Posted by David Smith on 26 Aug 2002, 6:01 p.m., in response to message #1 by Roger Hubbert
DO NOT use a glue to fix the posts. It WILL eventually fail again.
My recomendation is to use a plastic welding solvent sold at most hobby shops. It works by melting the plastic and letting it fuse back together, just like a metal weld. The ones I use contain the solvent methylene chloride (dichloro-methane).
Use a small brush to work the solvent into the cracked post (wet it pretty good) and then clamp it (or wrap with THIN wire, if you must). Let it set for at least 24 hours (dont believe the bottle instructions that say use sparingly and sets in 10 minutes).
