Re: RPL help. . . Message #2 Posted by James M. Prange on 11 Aug 2002, 5:15 p.m., in response to message #1 by Tal
To check whether the variable exists, use RCL within an IFERR structure,
like this:
'XXX'
IFERR
RCL
THEN
(whatever action to take if the variable doesn't exist goes here)
ELSE
DROP (whatever action to take if the variable does exist goes here)
END
You may want to refine the THEN clause by nesting a conditional (IF...
or CASE...) structure in there with ERRN to check that the error was
really #204h, "Undefined Name".
But note that this checks whether the variable exists anywhere on the
current path. To restrict the search to the current directory, maybe:
VARS 'XXX'
IF
POS
THEN
ELSE
END
But note that VARS is slow when the current directory is large.
What you want to do resembles what happens when the calculator receives
a file with the same name as an existing variable in the same directory
and flag -36 is clear, so there may well be a SysRPL entry that would
help you.
James
