I noticed that too... Message #6 Posted by Mike on 7 Aug 2002, 12:40 a.m., in response to message #5 by David Smith
But if the hole is really too low, you would not see an entire dot. It has to be right above the dot, doesn't it? The switch lever is not very wide (at least on the non red dots).
