Re: Rebuilding a Digital Cassette Message #2 Posted by Ellis Easley on 30 July 2002, 12:32 p.m., in response to message #1 by andy
Don't forget the end-of-tape holes. Might be tricky to punch them without creating a weak spot where the tape might break in use. Find a reliable way to measure the length of the tape on an original one - counting turns of the hub depends on the thickness of the tape, need to count turns of a capstan. I have some very similar tapes of another brand that have less, thicker tape in them that I want to reload. Get a micrometer to measure the thickness of the original tape, the correct length of the thicker tape wouldn't fit on the reels. I've thought of doing this too - I hope the tape in a Compact Cassette will be compatible (haven't taken a measurement yet). May need to use tape from a longer cassette, C90 or C120 min., to get the right thickness - if the width and coating are right at all! If Compact Cassette tape is too narrow, next choice will be to try to slit 1/4" tape.
