Re: speeding up an HP41CX Message #3 Posted by Tony Duell (UK) on 27 July 2002, 6:57 p.m., in response to message #1 by Theo Kastrissios
The timer chips in the time module and 41CX (both normal and halfnut versions) have their own crystal and are not affected by the speedup mod.
Nor should any ROM or RAM modules. But please remember that these modules were not designed to run at the higher speed, so some may not work correctly. You will just have to test all the functions of your machine if/when you've done the speedup to see if you have any modules that don't like it.
IIRC, the card reader doesn't work properly on a speeded-up machine. The Wand normally works _better_ on a faster machine. And some HPIL functions have problems (particularly if you're using a tape drive and have a file that spans the 2 tracks -- the machine can think the tape is taking too long to rewind).
