Re: The way that it is moved through the Meta kernel from port1 to port2. Message #2 Posted by J.C. Randerson on 19 July 2002, 10:41 p.m., in response to message #1 by Hiroshi Ito
I have MK 2.2 on ROM card, and it uses all of Port 1, nothing else can be stored there. You cannot then merge Port 0 and 1. (Try it, you'll get a "Port Not Available" error message.) You should still have about 120KB in Port O, and about 131KB in each of the remaining Ports of your RAM card. The MK filer will allow you to easily move things throughout this remaining memory. The MK Filer is probably the best calculator memory tool I've ever seen!
regards,
J.C. Randerson
Pueblo, Colorado
