HP Forum Archive 08
Re: Polar to Rectangular etc. on the 48 Series
Message #1 Posted by Ron Ross on 18 July 2002, 2:18 p.m.
While that conversion isn't quite as nice as on a 42s, it is still fairly straightforward.
Use your parenthsis above the division key. next key in the value: ie (3 4) Then use your green shift key and also use the polar (above the MTH key) and VIOLA!! Rect->Polar
Also works in reverse and also between(play with to understand) and also RAD conversions are also directly manipluated also.
