Re: HP 21 Rechargeable Battery Needed Message #5 Posted by Tony Duell (UK) on 15 July 2002, 6:23 p.m., in response to message #1 by Sarah Mulder
Why do you believe it needs 2 * 4V batteries? Every Woodstock (HP2x) series machine I've repaired runs off a 2.5V (or so) battery pack consisting of 2 AA-size NiCd sells in series.
If you have the oriignal battery pack, you can carefully cut it open, extract the original cells and put new ones in. If you don't have the original pack, you'need to find one, etiher working, or to be rebuilt. As a general comment, _never_ throw out old HP calculator battery packs -- the plastic housing, and some of the metal contact strips are needed to rebuild the pack.
