Re: HP-25: More common problems? Message #5 Posted by Juergen Rodenkirchen on 25 June 2002, 2:30 p.m., in response to message #4 by David Smith
Dave, thanks a LOT for your warning! I immediately unplugged the machine (which is an ordinary one, i.e. not a "C")! Fortunately, the machine seems to be intact as a test showed. However, I will follow your advice and charge the pack inside a different machine which is already broken (the memory chip doesn't work any more). Guess what? The "rebuilt" battery pack comes from the broken machine, so I guess you are absolutely right. Many thanks for your advice again!
