Re: HP-IL/RS232 made by "Firmware Specialists" Message #3 Posted by Ellis Easley on 26 June 2002, 1:14 p.m., in response to message #2 by Steve Borowsky
"I think the best way to proceed is to get the documentation for the HP product and try to derive the rest from there."
I was going to suggest that. I am familiar with the HP HPIL/HPIB interface and because both sides are addressable, the protocol is a little complicated. Since RS-232 is not addressable, it should be a little easier to do on the HP model and hopefully to figure out on another model. I have an old non-HP HPIB/RS-232 interface I want to figure out someday. I suspect mine might be a one-way convertor to allow a computer with only a serial port to control an HPIB printer or plotter in "listen only" mode, or to input data from an HPIB instrument in "talk only" mode. I have a non-HP multimeter like this - the mode and range have to be set manually, the HPIB only sends readings.
